Discussion topic: Eternet not working
This message was authored by: Mariega
Eternet not working
Ethernet is not working
Avatar for Mariega
Re: Eternet not working
Can anyone help
This message was authored by: mormegil
You would need to give more information and context to your enquiry in order for anything to be able to help you
@Mariega What is not working with the Ethernet connection that you are aware off!
Avatar for Mariega
I work from home , It department says I'm connected to internet and not the  etranet, I have turned off and in plugged but still the same
Ethernet is a physical cable that connect your device to your router
is this connected and if so have you tried other devices or cables or tried a different Ethernet port on the hub?
@Mariega Do you mean that your IT dept has told you that you are not connected too there Intranet! That is different and you need to take it up with them as to why not! Once you know that they should be able to help you!
