Discussion topic: Equipment packaging
This message was authored by: David_y
Message posted on 04 Apr 2025 05:08 PM
Equipment packaging
It seemsvthe virtual assistant can't answer this simple question. Do I need to keep the boxes my broadband and tv puck equipment came in?
Find out more
Message posted on 04 Apr 2025 05:29 PM - last edited: 04 Apr 2025 05:30 PM
Re: Equipment packaging
No, because should you ever need to return it and the puck then Sky will send you some packaging or you can use your own.
Find out more
Message posted on 04 Apr 2025 05:30 PM
If and when you cancel those subscriptions Sky will send out packaging towards the end of the relevant notice period but if you've got room it might be worth keeping it.
