Discussion topic: Engineer visit without entering the home.
Message posted on 13 Sep 2024 08:26 AM
Hello,
We've been having issues with our broadband for the last three days, primarily drop outs and lower download speeds. Calling Sky support yesterday, they offered to arrange an Openreach engineer to visit our house to fix the issue.
This is a problem for our household at short notice. I'm a carer for a disabled family member with severe anxiety relating to strangers entering the home. On the other hand, we naturally want the issue to be fixed.
How likely is it that the fault is at the local cabinet/exchange rather than inside our home? Would it be possible for the open reach engineer to only check the local cabinet instead of coming into our home? Anyone's experience or advice would be most appreciated.
Message posted on 13 Sep 2024 08:30 AM
Re: Engineer visit without entering the home.
@Trun0 They would normally check the connection and you will not know if the problem is in your home which has the master socket or if this is an external issue until the engineer does their checks.
Message posted on 13 Sep 2024 08:44 AM
If that's FTTC broadband then injecting a tone from the socket within your property to identify the circuit is very common.
