Discussion topic: Engineer appointment
This message was authored by Db67 This message was authored by: Db67
I had a engineer come out on 27th October. He couldn't connect tv and Internet, said there was a problem.  Had a txt this morning for another appointment.  The earliest one was for 10th November which I accepted but isn't soon enough as other provider disconnects on the 5 and I will be without any services
Re: Engineer appointment
@Db67  Your post has been moved from the Glass forum as it's not a Glass/Stream related isue.
If Openreach are unable to connect any earlier than the date provider there iosn't anything the forum can do to speed this up for you.
@Db67
I'd recommend you call your exisiting provider to see if you can keep the service live longer. It sounds like you may be moving from a copper based service to fibre?
I am NOT a Sky Employee
If this is a move from an ISP which doesn't use the Openreach network then unfortunately there's no obligation on anyone involved to organise/facilitate a seamless switch.
