2
This discussion topic has been answered Discussion topic: Earth net cable for sky max hub
This message was authored by: Spud10
Hi our tv internet switch has broken on the tv so I was wanting to cornet it by earth net cable but one we has are same size ends and to big for hub box.
anyone any ideas where I can get a cable that fits
thank you in advance
Re: Earth net cable for sky max hub
@Spud10
The plug used on ethernet cable is an international standard 'RJ45'
It's absolutely impossible to connect, for example, an HDMI socket on a television set to an ethernet port on a router: the signalling protocols and underlying data types are entirely different.
@Spud10 thereare 4 ethernet ports on the Sky hub which take the rj45connector every ethernet cable uses. Check that the cable youhave is in fact an Ethernet cable not forexample a USB or HDMI cable which have different .
@Spud10
