Discussion topic: Dropping connection
Message posted on 21 Apr 2024 12:31 PM
Dropping connection
My sky broadband keeps dropping connection; my phone, tv and laptop
are all going offline. I have checked the WIFI checker and it says everything's okay - but is isn't. It has been doing this intermittently all morning, every 10/15 minutes or so.
Message posted on 21 Apr 2024 12:51 PM
Re: Dropping connection
My internet dropped connection everything in and check tv all working correctly but just the internet.
Message posted on 21 Apr 2024 02:57 PM
@Katy1111Was this the test that you ran while the internet was having the issues
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
@sarah+lou+22 Could you please run the same test from the link above.
Message posted on 21 Apr 2024 09:10 PM
I'm having to book an engineer out as everything else is okay but my connection which is weird as I live in a block of flats. 🤷♀️
Message posted on 21 Apr 2024 09:20 PM
I have used the sky link & everything looks fine, but yet again my connection has dropped.
im on my laptop and it's come up saying 'the service provider in your current location is restricting access to the internet' what does this even mean.
how can I book an engineer? I often WFH so this isn't ideal
Message posted on 23 Apr 2024 08:48 PM
Contact number
Does anyone have the correct contact number for broadband issues. Getting really fed up mine dropping connections constantly and I'm struggling to find a number anywhere!
Message posted on 23 Apr 2024 08:53 PM - last edited: 23 Apr 2024 08:55 PM
Re: Contact number
You need to post your router stats so that someone who understands them can perhaps advise.
If you end up having to call Sky you can call free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
Message posted on 23 Apr 2024 08:59 PM
Internet dropping after power cut
On Friday we had a planned power cut by northern power. From Saturday I have been having constant issues with my WIFI. It drops regularly (at least once an hour)
I often work from home so I wouldn't be able to do this until sorted.
i have checked all the connections online and it says it's okay although my
speed has dropped to 6.4 mbps!
help! What could this be!
Message posted on 23 Apr 2024 09:03 PM
Re: Internet dropping after power cut
Your 3 threads have been joined. You don't need separate threads for one issue.
I merged your post with this one so we could see the full picture
Message posted on 23 Apr 2024 09:16 PM
Internet at ours is down and TV says it is but the checker says not here too. Chapeltown Sheffield
Message posted on 23 Apr 2024 09:36 PM
My Broadband has also been dropping out every 10/15 minutes. I work from home so it's really interfering with my ability to work effectively. The Broadband checker always says "everything is fine" 🙄! I've reset the router, unplugged it and plugged it back in again etc. I checked the status summary last time it dropped and it does say "Disconnected" against Broadband. I wonder if we just need a new router? The one we have is certainly not young! I just wish there was an easy way of telling Sky we have a problem so that they can sort it!
