Discussion topic: Dropping c
This message was authored by: DS24
Dropping c
wifi keeps dropping
Re: Dropping c
@DS24Do any of the lights on the router change colour when this happens?
Avatar for DS24
Re: Dropping c
No nothing, just sky glass crashes, no volume due to the lag.
Or volume but delay in scene..  or laggy gaming. I've called them and trying other options
Re: Dropping c
@DS24  black or white router from Sky?
Avatar for DS24
Re: Dropping c
I currently have the black. They are upgrading me to the white then signal boosters
Re: Dropping c
@DS24  So when is the new router coming out with the booster pod(s)? As if they are sending this kit out to see if this sorts the issue you will just have to see if this does help. But if it is dropping then the change of equipment might not be the solution.
If you have the black hub just now can you follow the directions in the link below.
Avatar for DS24
Re: Dropping c
New router first then if no improvement after 10 days we get the boosters..
Re: Dropping c
@DS24  Do you still have the black router connected to the broadband just now?
