Discussion topic: Drop outs
This message was authored by: John753
Drop outs
My network has dropped out 3 times this evening on all devices.
is there an issue in the area?
This message was authored by: Mustman1959
Re: Drop outs
Which area, John753?
Re: Drop outs
@John753
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
