Discussion topic: Drop outs in wifi
This message was authored by: CraigUk
Drop outs in wifi
Been having drop outs in wifi the last few days. In living room and daughters room. Our old vigrin WiFi 5 box used to have enough signal but the sky WiFi max signal seems to be poor in these rooms
Re: Drop outs in wifi
@CraigUk Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
