Discussion topic: Draytek 2765 modem/router as replacement for Sky ER115
This message was authored by C4-Hank This message was authored by: C4-Hank
Re: Draytek 2765 modem/router as replacement for Sky ER115
Hi there, I am going to ditch the Sky router as I've purchased a Draytek 2860 and 2862 , so hopefully I can get one or the other working with the help of your guide.
please share the How to Link?
Much appreciated David
This message was authored by Brugie58 This message was authored by: Brugie58
@C4-Hank
Follow my screenshots above and you should have no problem in getting it to work
This message was authored by bushiwarrior This message was authored by: bushiwarrior
Can I get a copy please
@bushiwarrior
Just copy my screenshots above
This message was authored by Neo247- This message was authored by: Neo247-
Please can you send instructions, thanks
@No2ID Please can you send information, thanks.
Hi there,
I have Sky Fibre which terminates int the house into an ONT, then Ethernet out of thet to WAN2 Input of my Draytek Vigor 2862 router.
I  followed setup details from the following web pages and everything seems to be working.
https://www.draytek.co.uk/component/content/article?id=387#draytek-router-setup
This message was authored by Bluemoon.007 This message was authored by: Bluemoon.007
Hi @No2ID  could I please have a copy of the userguide? Trying to setup a Draytek Vigor 2762ac, to replace my Sky Router. Thanks
As part of me post I added a Link to the info necessary which is info on the Draytek website, explaining the steps, that is what I followed, did you try that yet?
Hi, @C4-Hank, no I haven't. I thought I read in the posts, somewhere, they had included unnecessary steps. I'll give it a go. Thanks
This message was authored by davepark This message was authored by: davepark
@Brugie58 Good Morning, I am about to attempt replacing a Sky Q router with a DRAYTEK 2865. I would be very grateful if you would share the setup screen shots and any instructions that would help me.
Hi
Are you on FTTP or FTTC ?
The set ups are slightly different
Hi there, I have a Draytek 2862 router working with Sky Fibre. The fibre terminates in my property via an ONT device and from that is a LAN cable which connects to the WAN 2 port on my Draytek.
I also changed the WAN/Internet Access configuration m as per the Draytek how to info but basically added Option Number "61" and a bogus Sky account setup in the Data area which fits the ASCI characters in a certain format required by Sky which looks something like the following "123456789abc@skydsl|abcd1234"
I guess the same approach should work with a DSL connection but you would do the changes on WAN1 connection I guess.
FTTC I believe.
@Brugie58 FTTC I believe.
