Discussion topic: Downtime Schedule for Tv
Message posted on 07 Feb 2026 04:04 PM
I want to restrict the TV time for 2 hours a day. As per the advise I received from Sky customer service team, I created a profile fir the TV and then I created a downtime Schedule. As an example I created the Schedule as pause at 17:00 and resume at 15:00 assuming TV will have access from 3.00 p.m to 5.00 p.m. It works when I create the Schedule and when the TV is switched on again it will still work even after 5.00 p.m or before 3.00 p.m
I tried so many agents and they were absolutely useless
Message posted on 07 Feb 2026 05:56 PM
Re: Downtime Schedule for Tv
@Ndk Not sure if you are allowed to roll over past the 11.59pm time mark have you tried doing that with 2 entries?
Message posted on 07 Feb 2026 06:08 PM
To be clear,, is this a Sky Glass television?
Message posted on 09 Feb 2026 02:31 PM
I did create 2 schedules. But it is still the same
I did create two schedules. It is still the same
Message posted on 09 Feb 2026 02:32 PM
No, this is Samsung TV
Message posted on 09 Feb 2026 02:58 PM
@Ndk If you do a direct pause on the wifi does that work, also what is prioritised device wise with the sky Max hub!
Message posted on 09 Feb 2026 08:22 PM - last edited: 09 Feb 2026 08:23 PM
You cannot use a router schedule to limit live television reception unless the signal is arriving entirely online.
