Discussion topic: Download speed
This message was authored by: GeorgeG1992
Download speed
Ran a test and it says everything is fine but an indepedent test says 2mb p/s
Re: Download speed
@GeorgeG1992 if you measure speeds on a device connected to the hub by WiFi you are probably just messuring the WiFi speed. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
