Discussion topic: Download speed
Message posted on 06 Jan 2025 08:49 PM
Download speed
My WiFi is only downloading 64 and I have just upgraded to fibre I am not happy as it was working fine before this upgrade
Message posted on 07 Jan 2025 07:34 AM
Re: Download speed
@Arthur29 upgrading conection speed will not necessarily increase WiFi speed in your home which is determined by the layout and type of construction of your home. Various reasons why wifi speeds maybe indeed less first of which is if Sky have sent you a white hubs than and you have Sky Q boxes as these no lngerxact as wifi extenders with the new hub which require matched extenders pods which can come as part of the Wi`fi Max addon see https://www.sky.com/help/articles/sky-wifi-max
Another explanation is the new connection is in a different place and the hub has moved. The answer is getting extenders or switching off the hub's wifi and buying your own kit.
