Discussion topic: Download speed
Message posted on 16 Sep 2024 07:05 PM
Re: Download speed
I have a fire stick 4k max and I had to buy a wired extension as on WiFi Luna games were glitching. Even with a wired connection the download speed seems to be 88 with speed tests.
I also have a wired connection on sky q box but all apps glitch and sound cuts out on netflix YouTube them all. That's why I upgraded
The WiFi speed test seems reasonable though when doing to from my phone as on fast.com it shows 400 Mbps.
So unsure what is happening as I would expect a wired connection to be on a par with that?
That said I am sitting right next to router but if I go upstairs the wired speed on fast.com drops to around 100
Message posted on 16 Sep 2024 07:12 PM
Re: Download speed
The firestick 4k only has a ethernet chipset of 100Mbps but 4k only requires 25Mbps but in your case stability is more important that speed.
For true ethernet speed use a laptop etherneted via at least a category 5e cable
Message posted on 16 Sep 2024 07:59 PM
Re: Download speed
Is that the same with the sky Q box? There is a limit?
I will try a laptop to make sure thanks
Message posted on 16 Sep 2024 08:03 PM
Re: Download speed
Which version sky q box do you have. V1, V2 or V3?
Is it hdr capable?
I think q boxes v2 and v3 or gigabit
Message posted on 16 Sep 2024 08:12 PM
Re: Download speed
This one
Message posted on 16 Sep 2024 08:14 PM
Re: Download speed
I am afraid that one has 100Mbps ports
