Discussion topic: Download speed issues!!
This message was authored by: Lee250
I am getting nowhere near my minimum of 200 download speed! I have done multiple independent checks and it's less than 60! I'm paying for 313 download speed.
I need this fixing!!
Re: Download speed issues!!
If you are testing using a wireless device then the result shows local WiFi speed at that particular location within the property.
The Guaranteed Minimum Download Speed is over optical fibre and ethernet cable as far as the Hub.
