Discussion topic: Download speed fix
This message was authored by Zoe1812 This message was authored by: Zoe1812
Download speed fix
Continue to pay for but don’t get anywhere the minimum download speed. Can an engineer come out to look into the issue & provide a fix please? I run the sky app broadband tests and all are OK yet the statue on the app remain that I have a problem. Thanks
Re: Download speed fix
@Zoe1812When you run the broadband test. After it completes could you tell us what speed you are supposed to get between and also your minimum. If you are below that minimum then Sky have to send someone out to find out why this is happening.
