Discussion topic: Download speed dropping constantly
Message posted on 20 Jul 2025 09:23 PM
Hi my download speed keeps dropping when trying to stream on my Firestick, I test the connection through my fire stick and it is around 55-60 Mbps then drops to 1-7 Mbps making it impossible to watch anything.
Message posted on 20 Jul 2025 09:24 PM
Re: Download speed dropping constantly
I have unplugged the router to reset etc, router relocation is not possible.
Message posted on 20 Jul 2025 09:28 PM
@Jwyt What sky hub are you using, and has the firestick ever worked correctly before now!
Message posted on 21 Jul 2025 11:50 AM
Hi I am using sky hub model:SR203
with regards to the firestick I have not long got it but my Wi-Fi plays up fairly often when I am watch Netflix etc
Message posted on 21 Jul 2025 11:56 AM
@Jwyt If your hub is close to the firestick connection wise you may be best to look on amazon for the Ethernet connection kit that they sell, you will never ever halve to worry again about wireless connection!
And if it is not a wireless issue then think with Netflix you can go inspect what is happening speed wise to the stick!
