Discussion topic: Does the Unifi Dream Machine Pro/SE work with Sky FTTP?
This message was authored by: David3066
I've read a few posts discussing issues with Sky FTTP and the UDM Pro ( I think the SE uses the same FW).  The issues centred around MAP-T of IPv6 and was awaiting a FW update from Ubiquiti to enable the feature in the UDM Pro.
Can anyone using the UDM Pro or SE confirm if the issue has been resolved?
I'm contemplating buying a UDM Pro or SE to run our smart home of 100+ connected devices.  We have 20 wired and 80 Wifi devices and I'm getting fed up of IP addresses changing whenever our router randomly resets.  I have used up the maximum 50 IP reservations that the Sky Q hub allows.
This message was authored by: Euan5
Re: Does the Unifi Dream Machine Pro/SE work with Sky FTTP?
No, it is not fixed. Any device sky is plugged into stops working. I think sky generates 2 networks that then cause a loop that any ubiquity devices crash on.  I found this looking for a fix for it.
