3
This discussion topic has been answered Discussion topic: Does Sky uses CGNAT?
This message was authored by: happymorning93
Hi,
I'm recently looking at changing broadband and have recently signed up for Sky broadband.
However I forgot to check if Sky is using cg-nat and I cannot find similar answer on google. Does anyone know for home broadband if Sky is using cgnat ?
Thanks!
Re: Does Sky uses CGNAT?
@happymorning93 Sky do not use CG Nat as each connection is assigned a unique public dynamic IP4 address so they can change, are in practice seem pretty sticky - mine has been the same for 6 months or more.
In the last couple of years Sky have moved pools of IP4 addresses from their European operations to the UK to deal with growth.
@happymorning93
So you are not with sky at the minute?
I had a look at my public ip address on the router and it matches the ipv4 address on whatismyip so no cg-nat AFAIK
@happymorning93
CGNAT is typically found in cellular data delivery, not fixed-line broadband.
