Discussion topic: Disable IVP6
This message was authored by: SallyB19
Message posted on 06 Nov 2024 06:22 PM
Disable IVP6
How do I disable IVP6 on the my sky app. I can't find it absolutely anywhere.
Find out more
Message posted on 06 Nov 2024 06:45 PM
Re: Disable IVP6
@SallyB19 straight forwardly you cannot disable IP6 for the white WiFi Max hub from the app. You can do so on the older black hubs in their weg interface. However there are no reason why you should need to do that. If you explain what your are trying to do forum members should be able to help.
