30 Nov 2023 08:32 PM
Trying to disable Broadband Shield, but can't log into it. Any ideas?
30 Nov 2023 08:50 PM
Posted by a Superuser, not a Sky employee. Find out more@TaDaaaa you havecto be using the Sky id that is linked to the account holder. If you are confident you are you will need Sky's help.
30 Nov 2023 08:55 PM
You can also try to connect via the app on mobile data rather than WiFi to see if you can turn of the shield
