Discussion topic: Disable 5ghz
This message was authored by: Janda
Disable 5ghz
I need to disable the 5ghz option and have tried the suggestions on previous posts but nothing worked. I have uninstalled and reinstalled mysky but that didn't work. I pressed the wps button on the hub, it flashed then stopped flashing. I logged back into mysky but I can still only see the broadband shield option. I logged onto the ip address but it asks for a login from there.
Any other suggestions please? Thanks.
This message was authored by: Me134
Re: Disable 5ghz
To log into the IP web address you enter admin as the user name and the password on the bottom of the router (even if you've changed the wifi password).
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
Re: Disable 5ghz
@Janda what is the colour of your Sky hub?
Avatar for Janda
Re: Disable 5ghz
It's black, 4.2 I believe.
Re: Disable 5ghz
Arrggg, it sounded like a Max hub you have, my bad.
Not a Sky employee
