3
This discussion topic has been answered Discussion topic: Difference between white hub and black hub
This message was authored by: Chloe142
Hello what is the difference between the white hub and the black hub. Can they both be used for ultrafast or is that just for the white hub thanks
Re: Difference between white hub and black hub
@Chloe142
The black Sky Broadband Hub is compatible with FTTP.
The black Q Hub will work for broadband over FTTP but doesn't support Sky Talk Internet Calls.
Both of these are WiFi 5: the white Max Hub is WiFi 6.  Only Max now has Parental Controls.
@Chloe142
Avatar for Chloe142
Level 4 icon
Many thanks
This message was authored by: UK+Sgt+7094
any idea what has the better range, we got the new white hub and it does not seem the best for range and stability combined with the new sky pucs. having some real issues.
