Discussion topic: Devices keep disconnecting and say no wifi
Message posted on 30 Sep 2024 08:25 PM
None of my devices are working consistently. WIFI constantly drops. For example my firestick stops every 30 seconds or so, sometimes comes back on or says no internet connection.
My sins smart tv is the same. Both seem worse in the evening.
Message posted on 01 Oct 2024 07:41 AM
Re: Devices keep disconnecting and say no wifi
@Carly9185 WiFi issuescthst get worse in the evening are often caused by interference. There are a few things you can try firstly make sure your hub is out in the open idealy on a surface somits signalscare not blocked by furniture radiators and the like. It is also worth rebooting your hub as thstvwill make it find the least congested channel to use.
