Discussion topic: Devices connected to wi-fi extender
This message was authored by: Gaz14
Hi all, I am constantly having issues with my broadband/wifi being slow, I have acted on suggestions to improve but still not much success, when trying to load pages it can take sometime however loads immediately as soon as I turn wi-fi off on device, I also noted that nearly all devices are "wi-fi extender" connected however several are Ethernet connected, anybody have suggestions before I move to new supplier, I was BT previous and never had any issues even though speed 21meg was the same,
thanks
Re: Devices connected to wi-fi extender
@Gaz14 you can probably ignore the device id issue which appears to be a bug. Can you post your hubs stats as thst will help forum members see what is the issue see Find your Sky Broadband router statistics
Avatar for Gaz14
Thanks Chrisee, have done that but it will not let me post due to a HTML error whatever that means but thank-you will try and get it on somehow
