Discussion topic: Delayed broadband installation
This message was authored by: dcgratty
Why is it taking so long to connect my broadband following our house move? We moved in on 6th September, was originally quoted go live for 13th Sept but was then moved to 9th Oct and no one can tell me why.
Re: Delayed broadband installation
@dcgratty
For new FTTP installation that's typically down to the availability of Openreach resources in the local area.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Avatar for dcgratty
@TimmyBGood
Thanks for responding, see screen shot. All seems to be ok?
It does all seem to back up with BT Openreach but as Sky is the customer effectivley there doesn't seem to be much I can do?
@dcgratty
What does it say in the first couple of lines below the table?
