Discussion topic: Decanted for 4 weeks
This message was authored by: Teamplayer
I am being moved home for 4 weeks due to all of my floors being pulled up and fixed , I will still be living in the same area 5 minutes from my current home until the job is done , so I'm not moving home but I won't have my skybroad band , can I have help with this as I really need to have Wi-Fi
Re: Decanted for 4 weeks
@Teamplayer
Sky do not do short term (and in your case very short term) subscriptions.
@Teamplayer
Realistically you'll need to look at cellular data: fixed-line ISPs have significant up-front cost to provision a circuit which is then paid back over the minimum contract term.
This message was authored by: Me134
To add to the above, it takes time to cancel down a line and start up one at a different address, this would also have to be done in reverse when you're moving back. I doubt you'd have any BB even if they agreed to do it for the 4 weeks and you may even be without for longer than the planned 4 weeks.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
