Discussion topic: Damaged cable, can the replacement be sent?
This message was authored by Jessica2022 This message was authored by: Jessica2022
Good morning
My cable (attached the photo) has been damaged by my dog. The cable has a purple end and plugs into a socket. I have no internet at all. Can you send the replacement please? If not and I have to purchase it, can you tell me which one I need to buy.
Thank you
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
Re: Damaged cable, can the replacement be sent?
@Jessica2022 wrote:
Good morning
Thank you
  • As we are customers on the forum we can only provide advice.
    However, if you want to discuss an issue with Sky, for the general-purpose number click on "Need more help" at the bottom of this page
    https://www.sky.com/help/home.
    If you are in the ROI set the flag at the bottom of the page accordingly.
    If you have Sky Talk or Sky Mobile dial 150 for a free call to Sky.
    When you call you will be asked if the call is to do with mobile say "No"
    You will then be asked the nature of the call say " Technical "
    You will be offered a text to the number you are calling on, say "Yes" and a text will be sent DO NOT hang up when it says to do so.
    It will then ask "do you wish to hang up" say " No" you will then be put in the queue for an advisor.
    I hope this helps.
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
@Jessica2022
Best option would be to go to currys, pc world, dixons etc and ask for a rj11 to rj11 dsl cable for a couple of £'s
@cookiemonsteruk wrote:
@Jessica2022
The one in the image appears to be BT-jack (431A) to RJ11
@Jessica2022
@TimmyBGood depends which one was mauled . I was going by reference to the purple dsl cable
@Jessica2022
It's confusing me: the socket appears to be RJ11 but I can't figure out why.
@Jessica2022
Good point i thought the phone cable was hiding the phone socket but dsl socket is too centrally located for a prefilterd mastersocket 🤔  possibly sogea ???
