Discussion topic: DNS Issues
This message was authored by: chriso3
Message posted on 20 Jun 2025 07:49 PM
DNS Issues
I find browsing to new web sites takes about 10 seconds to find the page. Then loading the page is really quick.
Changing dns to 1.1.1.1 solves the issue.
How can I ask Sk to check the DNS server I am connect to is OK?
Message posted on 20 Jun 2025 07:57 PM
Re: DNS Issues
@chriso3 You are only connected to sky's DNS server's with the sky hub, you want something else then you need to do it on the device if it allows you to change, NO other way!
Message posted on 20 Jun 2025 09:27 PM
Re: DNS Issues
Thanks Jim
