This discussion topic has been answered Discussion topic: Conversion kit
Message posted on 10 Jan 2026 03:43 PM
Had a message to say conversion kit would be delivered today Sat 10th Jan all that arrived was an etheret cable but paperwork inside envelope said should be a router please help
Message posted on 10 Jan 2026 06:04 PM
I had the same issue but all I received was a torn envelope with two pieces of paper. No cables, nothing. Spoke to the Sky call centre, who were totally useless. No idea what had been sent, no idea what to do. So it appears i should have been sent a cable. Any ideas how to contact sky other than there offshore call centre which is next to useless?
Message posted on 10 Jan 2026 05:43 PM
Re: Conversion kit
If you already have a Sky Broadband Hub and didn't opt to add the WiFi Max subscription supplement then the ethernet cable is all you get: it links the newly installed ONT to the Hub.
Message posted on 10 Jan 2026 06:11 PM - last edited: 10 Jan 2026 06:12 PM
Re: Conversion kit
Personally I'd suggest acquiring a Cat5e ethernet cable in whatever colour and length you prefer, otherwise you'll need to persist with getting through to someone useful in a contact centre.
