Discussion topic: Continued connection loss
Message posted on 28 Aug 2025 10:07 PM
Error tvq-pb-101-(3.1.6) continually losing connection watching Netflix etc, router restarting makes no difference. States internet speed is 0mbps
Message posted on 29 Aug 2025 06:54 AM
Re: Continued connection loss
@Bradders5 what do the lights on your Sky hub show see https://www.sky.com/help/articles/hub-lights-explained-start
If the hub remains connected the issue is likely to becwithin your home. To stream video with apps like Netflix you need a good stablecwifi connection. In many homes a single Sky hub cannot give usable WiFi in every room and you will needca boister or extender .
Message posted on 22 Feb 2026 10:55 AM
So Sky knew internet was down in my area. Issue fixed by next morning (Saturday.) Nownits gone done again and showing error code:
tvq-pb-101 (3.1.6)
Unplugged router, reset modem and still nothing but Sky app says there's a connection. There is not. I know what the two orange lights represent, it is down despite connection.
Discussion forum responses same as everything I've tried and customer service just recommend links to broadband pages which I've already tried multiple times to no avail!
Is Sky being hacked?
Message posted on 22 Feb 2026 10:59 AM
@Thistlegirl74 wrote:Unplugged router, reset modem and still nothing but Sky app says there's a connection. There is not. .
@Thistlegirl74
What leads you to the conclusion that Sky have been hacked?
Message posted on 22 Feb 2026 12:14 PM
Nope, it more likely the fault could have reoccurred so does anything appear again on the status page for you:
https://www.sky.com/help/servicestatus/your-services/broadband
