Discussion topic: Continued Outage
This message was authored by: Sarah394
Continued Outage
Experiencing continued periods of outage through broadband, all checks show no issues but still unable to connect.
Have followed badoc troubleshooting which has not resolved the issue currently, this has been for the past 48 hours.
Re: Continued Outage
@Sarah394
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
▪️I AM NOT A SKY EMPLOYEE ▪️
