1
This discussion topic has been answered Discussion topic: Continual fault
This message was authored by: MelHarvey1
Continual fault
Hello,
Ive been having issues with your service for a couple of weeks now. I've had two engineers out, and they have tried their best, but my internet is constantly cutting out, some times for 30 seconds,  but usually for 30 minutes plus.
It's affecting ny business as I often work from home.
I'm basically running my house from my EE hotspot now, and have updated my package to unlimited data as the Sky service is so patchy.
Ive run all the tests etc from your website, as I type this it's not working, but according to your checks.... its fine.
I'm really getting sick of this now.
Please check the account history and see how many times I've been left without any service.
I'd like to cancel both my tv and broadband package, as you can't provide me with a service I'm being charged for
Re: Continual fault
@MelHarvey1
We are customers here on a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
If you’re still having problems you may need to contact Sky again to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
To cancel Sky Broadband and Sky Talk the below link explains how to switch to an alternative provider or the various methods on cancelling completely.
https://www.sky.com/help/articles/cancel-sky-broadband
If you try to cancel whilst still in a minimum term deal you might have to pay an early termination charge (Sky will notify you if you do and how much they’ll charge).
NOTE: One Touch Switching only applies to broadband and Talk and NOT a TV subscription.
Return packaging for any equipment Sky expect back will be sent out to you near the end of the 14 day notice period. Remember to keep any proof of posting indefinitely.
To fully cancel your TV subscription, if your minimum term has ended you’ll need to give Sky the required 31 days notice. Note that the latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree. (If they agree you’ll have to pay the remainder of your discounted term).
See the below link
https://www.sky.com/help/your-account/my-account-and-subscription/cancelling/cancel-my-subscription/...
Select ‘No, I still need help’ at the bottom of the link which will lead to contact methods.
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ It may include a phone number, an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ there’s a text option (Monday-Friday 9am to 4:30pm) otherwise it’s only by calling Sky Ireland or writing in.
If you successfully cancel you should receive an acknowledgment email from Sky.
If you are cancelling Sky Q, return packaging will be sent out near the end of your notice period. It’s important that you obtain proof of posting and keep it safe and indefinitely.
Re: Continual fault
@MelHarvey1
See the below link
