3
This discussion topic has been answered Discussion topic: Contact Sky/Openreach To Move ONT
This message was authored by: Chay3
Does anyone know how to contact Sky to have the ONT moved? We're having building work done and the plug socket is being moved, so there wouldn't be a power source in its current location. I appreciate this would be chargeable but I can't find a way to get through to anyone.
Re: Contact Sky/Openreach To Move ONT
@Chay3
You can't contact Openreach direct. You have to contact your ISP.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
@Chay3
Avatar for Chay3
Hi @Daniel0210
Unfortunately, when I ring up and select the option that I'm an existing customer by pressing 1, it just cuts me off everytime. Thanks though!
@Chay3 use the phone registered to the account which should bypass that check.
