Discussion topic: Constant drops
This message was authored by: Abrayford
Constant drops
My WiFi constantly drops out, devices have to reconnect including my phone. Even this morning reporting this issue my phone's connection to WiFi has dropped out 3 times. I've not had this issue before and I put it down to the router as I was with BT before with no issues and this is the same ljne.
This message was authored by: Me134
Re: Constant drops
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for Abrayford
Re: Constant drops
Thanks. I've restarted the router a few times and with no success and also I don't see why I should upgrade to not have internet dropouts.
I have tried the app which says everything is fine but it still drops and even dropped while running it.
A new router may solve the problem as that's the only issue I can believe it to be but any advice appreciated.
