Discussion topic: Constant broadband failure
This message was authored by: Coney2000
Every day my broadband fails. I have to go to the box, restart it and run the speed test. It then works until the next day. The speed tests say my broadband is fine. But I am struggling to work from home with this set up and often my alarm in the morning does not work.
This message was authored by: Harj252
Re: Constant broadband failure
Same issue, sick of it. keep being told to switch off and disconnect for 30 minutes.
Sam issue occurs.
