Discussion topic: Connectivity
Message posted on 01 Feb 2026 08:34 PM
Connectivity
My connectivity is always soo bad, I joined sky few month ago and always bad connectivity. It always drops, videos are always loading so much. At second floor its even worse. At first I thought maybe becase we are far from the hub but still when in thesame room it just drops by itself. Did anyone had the same problem? What should be done. I have one more year of contract. Is this sky or what?
Message posted on 01 Feb 2026 08:47 PM
Re: Connectivity
@CS43 Try a five minute power off on the hub as a reset to it, also what sky hub are you using on the connection?
Message posted on 01 Feb 2026 09:11 PM
Re: Connectivity
Its the sky max hub the white one
Message posted on 01 Feb 2026 09:22 PM - last edited: 01 Feb 2026 09:29 PM
Re: Connectivity
@CS43 Do you have any extra form off boosting being used with your white sky Max hub, or is it the hub as the only source?
