Discussion topic: Connections issues
This message was authored by: Foxyfaz25
Connections issues
Connections seems really slow buffers and sometimes don't connect at all tried rebooting system and doesn't make a difference got worse over months
Re: Connections issues
@Foxyfaz25 If it is as bad as you say then run the diag linked below, when it finds the fault it will guide you to what needs to be done!
Try running the line test here to see if any faults are found:
