Discussion topic: Connection
Message posted on 18 Sep 2026 09:19 PM
Connection
The connection to my new sky glass telly is awful, the program I am watching keeps buffering.
Message posted on 19 Sep 2026 04:51 AM
Re: Connection
@Laurenc1994 to stream video you need a decent WiFi connection or better use an Ethernet cable.
If you are a Sky Broadband customer poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
