Discussion topic: Connection
Message posted on 04 May 2026 06:15 PM
Connection
Nothing will connect and WiFi box showing a red light
Message posted on 04 May 2026 07:32 PM
Re: Connection
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
