Discussion topic: Connection
This message was authored by: Dainis
Message posted on 10 May 2025 10:55 AM
Connection
Sky Q box keep disconnecting from WiFi. My sky app test states that everything is fine but sky box settings says no WiFi connection.
Message posted on 10 May 2025 11:09 AM
Re: Connection
@Dainis If you could just say what you are seeing on the Hub lights, link below will give you the idea, and you can say which one you also have hub wise.
