Discussion topic: Connection
Message posted on 09 Dec 2024 03:05 AM
Connection
Cannot connect my iPod to my wifi
Message posted on 09 Dec 2024 05:45 AM
Re: Connection
Are you able to connect other devices, if so what is happening when you try to connect it ?
Message posted on 09 Dec 2024 06:54 AM
Re: Connection
Yes I am able to connect other devices, when I try to connect iPod touch too the network, keeps saying login failed
Message posted on 09 Dec 2024 06:58 AM
Re: Connection
@BrianMorgan which Sky hub do you have? If it is the whitectype try changing the WiFi security setting from WPA3-T to to WPA2 using the hub's advanced settings page in the My Sky app
