Discussion topic: Connection
Message posted on 19 Apr 2024 10:17 PM
							Connection
Message posted on 19 Apr 2024 10:26 PM
							Re: Connection
Message posted on 20 Apr 2024 06:29 PM
							Re: Connection
@John6854& @MBUK1975 Has you broadband connection worked before this and it is because your broadband connection has a fault?
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 21 Apr 2024 05:12 AM
							Re: Connection
Mine is working perfectly now 🙂
