Discussion topic: Connection with Sky Box keeps dropping
Message posted on 09 Jan 2025 09:45 AM
We had a new Sky Max box installed about a month ago but the wifi connection keeps dropping after 5 minutes of connection on Sky box, we also cannot get any connection with the sky mini box upstairs. Have reset all devices many times. Signal is ok on other devices apart from upstairs where we struggle to get connection. Router is in the same room as main Sky box
Message posted on 09 Jan 2025 12:26 PM
Re: Connection with Sky Box keeps dropping
Hi @Paul+QPR
Are you connecting the Q box via WiFi or ethernet?
Have you done a complete network reset on all Q boxes since getting your Max hub?
Message posted on 09 Jan 2025 01:48 PM
Thanks @jamesn123 - it's connected via WiFi and yes have tried the network reset on the boxes but unfortunately we still keep loosing the connection
Message posted on 10 Jan 2025 03:19 PM
Did you use any boosters previously?
Message posted on 14 Jan 2025 08:34 PM
No not previously. We used to have a pretty strong signal everywhere in the house before the switch
Message posted on 14 Jan 2025 08:36 PM
No not previously. We used to have a pretty strong signal everywhere in the house before the switch?
Message posted on 15 Jan 2025 10:44 AM - last edited: 15 Jan 2025 10:45 AM
That is odd, you wouldnt expect coverage to reduce that drastically. Is the router in the same place and everything? Is your Sky Q system all connected with hotspotting enabled?
