Discussion topic: Connection speed
This message was authored by: Hatty60
Connection speed
Hi, on just testing my connection Avast are saying DL 7.83 UP L 0.42??? what is going on here? Your saying its in the 20, s rubbish we have buffering all the time?? what am I paying for?? 😡
Re: Connection speed
@Hatty60
Is the device you are using connected via WiFi or ethernet?
I am NOT a Sky Employee
Avatar for Hatty60
Hi, Wifi
This message was authored by: JPR007
@Hatty60 You are paying for a fixed line broadband connection, either via a fibre optic cable or over your copper telephone cable....
The speed that Sky (and every other ISP) go by and your contract is linked to, is the connection speed up to the router, not what you get at the end of a WiFi connection on a phone 🙃
If you are recieveing your guaranteed minimum speed that is stated in your contract (you can check on the MySky app) then they are fulfilling there contract to you 🤓
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for Hatty60
Hi, Open reach have supposed to have upgraded the lines to all the property's here we're rural so that accounts for the slow connection speed then 🤷🏼‍♀️🤨
