Discussion topic: Connection problems
This message was authored by: Lucia14
Connection problems
For over 24 hours we have had on and off issues with our WiFi. We have lost connection despite the app saying no issues. It has stopped us from being able to watch tv or connect to the internet for most of the day
Re: Connection problems
@Lucia14 Run the test below!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
And if needed also!
Try running the line test here to see if any faults are found:
