Discussion topic: Connection no good
This message was authored by: Pink3
Connection no good
My old connections ran in my garden and kitchen this Dosent
Re: Connection no good
@Pink3 no isp guarantees wifi outside the property but poor WiFi coverage in the home is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
