Discussion topic: Connection issues
This message was authored by: Samantharowe
Connection issues
My internet keeps going off and on all the time has done since Friday it's getting really frustrating now I will reconnect eventually but it's soon f this all the time
Re: Connection issues
@Samantharowe Run the diagnostic to checkout what is possibly happening, link is below for you!
Try running the line test here to see if any faults are found:
