Discussion topic: Connection issues
This message was authored by: NigelPhillips
Connection issues
Hi
no sky broadband please helpme
This message was authored by: Eileenbsky
Wifi off
Box has no internet light , orange voice light , service checker says everything ok but not only person reporting this issue
This message was authored by: DC175
Re: Wifi off
Same issue here
This message was authored by: Wolves_Hero
Re: Wifi off
Same here Wolverhampton cut off 2 times. I use 5G network on mobile with hotspot WiFi connected to my PC, lucky 26Gb data left
This message was authored by: Damienxxx
Re: Wifi off
Same from this evening in Watford and now Skymobile is down
This message was authored by: Connor3421
Re: Wifi off
Same in Hertfordshire i think it's the whole uk lol ridiculous
This message was authored by: DanielleB1
Re: Wifi off
Down here in Newcastle. Box is flashing green and no internet connection but sky say there's no connection issues... brilliant
Re: Wifi off
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach. Hopefully it'll be back up and running before 7am.
This message was authored by: Chazzle
Re: Connection issues
Same issue for me - orange light in internet and voice.
Can we get confirmation on whether this is an outage?
This message was authored by: AC1305
Hi. Same issue for me too
@AC1305 @NigelPhillips @Chazzle same advice check the lights on the hub see https://www.sky.com/help/articles/hub-lights-explained-start if thst indicates the hub has lost its connection and a simpke rebootvdoesn't sort it there is a fault. Running the service checker in the My Sky app overca mobile connection will tell you if Sky arexaware of a fault local to you. If it doesnt call Sky to report the issue so it can be checked out.
This message was authored by: Manchester1999
My Internet isn't working iv done all the tests unplugged the router and despite it coming back on for 10 minutes it's off again
This message was authored by: KatieH3
Also all tests say ok and no outage, same problem keeps dropping
This message was authored by: Ikkleruby
I'm in Greater Manchester. It's 8.43am and we've not had WiFi all morning. Anyone know if sky are still denying there's an issue?
I'm in the London area and I have done all the checks and rebooted. Nothing. Showing as No outage in area
