Discussion topic: Connection issues
This message was authored by: Anna_1602
Connection issues
I live in a tiny bungalow and can't stay connected to the hub unless I'm next to ut
Re: Connection issues
@Anna_1602 your home might becsmall but if it has solid brick walls internally it can be very difficult to network using WiFi.. You maybe able improve things by making sure the hub is on a surface out in the open so it is above obstructions like radiators.
Sky can supply extenders if you buy their WiFi Max package https://www.sky.com/help/articles/sky-wifi-max but in buildings with solid walls that system is not thst effective. There is third psrt equipment you can buy powerline adapters are one solution that can work as tgst uses mains wiring to carry thecdata.
Avatar for Anna_1602
My router is in the front window behind the tv
@Anna_1602 Not the most ideal place to have the sky Hub situated!
Getting the best out of your broadband | Sky Help | Sky.com | Sky Help | Sky.com
That's where the engineer put it when it was installed. Why is it not ideal?
This message was authored by: Waveman
There is a lot of metal in TV's and noisy electronics. WiFi is not great at dealing with electronic noise and going through metal.
Try moving it and see if it improves then figure out how to relocate it.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
Thank you so much.. I appreciate your help.
